Battery "Groups"
Believe it or not, it's almost strictly the dimensions of the battery.  All group 24's are the same size, all group 27's are the same size, all group 30's are the same size... but if you change the type of battery (flooded, gell, AGM) then they will produce different Amp-hour ratings.  Also, the thickness of the plates inside the battery will have a bearing on the type of battery (thin plates in a starting battery, thicker in dual purpose or deep-cycle batteries).  The "group" will only tell you whether or not the battery will fit into your mounting location; It really tells you nothing about the capacity.--Jon BastienH23 '2 Sheets to the Wind'H25 'Adagio'
