Mark Cooper
Okay, so you guys talked me into it. I went to West Marine this evening about bought the great, splendiferous Spinlock rope clutches to replace the *(*$&#@@$ cleats on my 240. Just a couple of quick questions to those of you who've installed them before I get to my boat without the proper tools:1) On the 240, are the current screws hold the *(*$&#@@$ cleats tapped or bolted through? I haven't taken them off yet and don't recall; but though I saw bolts and nuts beneath the access panel. 2) I bought bolts, nuts and washers to fit the new rope clutches, but notice that some of you used the existing aft bolt to mount them, using a dremel tool or the like. Did you just have to drill out the smaller 10/24 hole to fit the 1/4" hole? Or did you have to also widen the countersink hole?I appreciate the info. I'm quite a distance from my boat at present so can't go look to find the answers to my questions. Plus, I want to follow in the footsteps of those brave souls who've drilled holes in their new boats before I start.
