Solar
My panel delivers 11 watts at peak output, which is only about .8 amp. If you left it charging for a long period of time without ever discharging, then you might worry about overcharging. I doubt you will have that problem. Regulators become important as the amps go up. Locating the panel where it is out of the way and in good sun is the biggest problem. Mine is a flexible number from Unisolar, and somewhat portable. It came equipped with an in-line fuse. I believe the difference between using a "starting" battery vs. deep cycle would be negligible in this situation.I use a pull start on my outboard, so I only have the deep cycle (105 amps). About once a week, I might stay overnight in a cove. I run my nav lights, my interior lights, and a a/c boombox from a 140 watt inverter (not all night, of course). On these overnight jaunts, I might use 20 amps, so to recover that, I need about four good sunny days for the panel (.8 amp x 6 hours sun x 4 days = 19+ amps). If I'm sailing by day and running the stereo, there is basically no loss from the battery. If LED nav lights ever get cheap, I could cut the draw significantly and get much more out of my battery. Incandescent lights are huge wasters of energy.Hope this helps.
