Jim
Hi all, Trying to sort out what kinds of limitations, if any, I should put on the use of electric lights on our O'Day 30. We have two "large" (sorry I don't have specifics at the moment) batteries on board which are charged solely by the alternator on our 16 HP diesel. We don't have dock power as yet. My bias is to use these lights very sparingly and rely primarily on candles or our oil lamp in the evenings rather than risk running either battery down such that we can't start the engine. I use a separate battery operated anchor light rather than might mast head light for anchoring for the same reason.Is this too conservative, over the top, reasonable? My sense is without having some kind of an ongoing load test available to you while you're out there, you really can't know with great accuracy how much stored power you have...loose belts, alternators or batteries potentially on the decline, etc., all can contribute to battery drainage beyond the lowest threshhold needed to start the engines. Overly cautious here? What do most folks do? Inputs most welcome..Thanks,Jim
