I find the idea of dragging my laptop along to and from the boat, and the possibility of it getting damaged, a bit disconcerting.
So I've come up with this idea.......
In a server based environment I've used the Wyse "Thin Client" workstations. The client is basically a computer without a disc drive. The intent is that everything it needs is available via the server. And in a Citrix environment the server may actually run the applications.
Essentially you have a small computer. And it runs on 12 VDC
I bought a V90 (information here) one on Ebay (click here to search Ebay). Paid $89 plus shipping. The one I have is a 1GHz processor, has 512 MB of memory and runs on XPe (embedded). There are two serial, and three USB ports. A PCMCIA slot, 10/100 MB Ethernet, VGA, and a parallel port.
I added a PCMCIA wireless N card (there is also an installed wireless option for the V90), and a USB memory stick.
In my testing I have a cheapo Delorme USB GPS, and their USB to Serial converter program running.
So far, I've been able to run Open GPL, Sea Clear, Memory-Map Navigator, and the Nexus FDX software reliably. Using the M-M Navigator (my favorite) I've been able to define waypoints and track on another machine, save them to the stick, and import it to the application running on the V90.
On the workbench at 13.5V, (running the apps, and connected using the wireless) it draws between 1.0 A and 2.0 A. Depending on what it's doing at the moment.
With a smaller size (8.5" x 7.5" x 2") it should be easy to mount it somewhere out of the way on the boat.
I have to admit, if you're not accustomed to working with computers, the reconfiguration might be a bit daunting. Resetting permissions, disabling client software and such. But not that bad. A dummy like me can do it.
The end result is that for about $200 investment, thus far, I have a computer that runs on 12V, that will be permanently mounted, runs charting software, and has internet access when in range.
