Hi.:
I've sailed my VEGA over a period of over 30 years; I've entered many regattas
and have many 1st, and 2nd finish trophies. There were only a few similar boats
I had to look at their stern. (One being the 25 ft. Catalina, she's better in
light air).
What to do for being better? Tack (jibe) at the right time, stay out from being
shadowed from another boat, learn to get up the spinnaker in record time, and
never give up. When you made a mistake, learn from it. And watch the wind! As
for the boat, make sure your sails are balanced; too much weather helm makes the
rudder acting as a brake.
Happy sailing, Wilhelm
________________________________
To:
AlbinVega@yahoogroups.com
Sent: Mon, July 12, 2010 5:48:00 PM
Subject: Re: [AlbinVega] Re: On the wind
Thanks for the many helpfull replies as usual, i got new sails last year and it
has made a differance for sure i tend to struggle in a bit of a blow but i know
i need to work on my sail plan ie a smaller foresail (maybe next years
expenditure). I was just curious to see if there was anything other people may
be doing that i am not, i will read all the previous posts/blogs on this.
Douglas i know that the vega's are an older design and i would not compare the
windward capabilities to a keel boat, but i see no harm im trying to achieve the
best i can from her with a little help from experiance!
regards
scott
891
To:
Sent: Wed, July 7, 2010 2:51:48 AM
Subject: [AlbinVega] Re: On the wind
I decided to bend the original mainsail this year, as well as run for a season
without the furler. The original mainsail and the original non-furling sail
inventory are all 35 years old. As such, I noticed that she doesn't point quite
as well as with the newer 155 and full batten/newer mainsail. However, she is
easier to balance and I find I can often sail with only a bungee tied to the
cleats and tiller.
So, I second Peter's advice. Newer sails will help. Also, a full batten mainsail
will help. At what wind speed are you having the most problems? Depending on the
wind conditions, I find that I can point to about 45 degrees off the
wind...sometimes even less than 45. But at low winds (below 8 knots), it tends
to drop off a bit.
Jack
