I recently posted a pic of a friend's boat that had been frozen into its slip -- until he turned his bubbler on. He knows, and accepts the risks, that he'll lose electricity if an ice storm hits his marina. I'd be curious to know how many of you, who keep a boat in areas of the country that freeze, keep your boat in the water over the winter, or haul out?
In my particular case, it is much less expensive (read on...) to keep my boat in the water over the winter than to have it hauled and blocked. But it is only less expensive if I have no damage by leaving it in the water. I realize that many boats can suffer through a harsh winter in the water, with or without a bubbler. Yet the one winter I did keep a boat in the water, it turned out badly -- for me and the boat. It snowed quite a bit that year and I tried to get to the boat to make sure all was well. Getting into the marina and then down the snow/ice covered docks, was a challenge. I slipped and fell, hurting my hip. When I got to my slip, the docklines had frozen solid, and the boat was frozen solid in the middle of the slip. If I could have gotten onto the boat, I would not have been able to either move it or to remove the ice and snow. I went home, poured myself a Capt Morgan Spiced Rum, and worried about it. Some weeks later, when Mother Nature eased up a bit, I went back. The boat was now free of the ice with about a 3-inch clearance around the waterline. Everytime the boat moved, it chaffed against the ice at the waterline. In the spring, when I did a short haul to bottom paint, I had "dock rash" (or rather "ice rash") and small gouges all around the waterline that required a lot of filling, fairing, wet sanding, and eventually painting, to restore. I have never left my boat in the water since.
What do you do -- and why?
