On a 41DS (2007) : Can't get access to water tank
Aug 11, 2010
28
Hunter 41DS Bristol, RI
My starboard water tank doesn't fill past half way. Can't find a way to get under the white plastic subfloor for access.
Hope someone has some advice. Thank you.
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Water did you check if the vent is plugged?
Aug 11, 2010
28
thanks for the response. No I haven't checked the vent. The water fills perfectly fine, but then the water gauge only goes to half way. max. I'll check the vent as you said, and try to open the fill and confirm the water level, just to verify again.
thank for your help. I'll get back
Nodak7
Sep 28, 2008
1,256
Is the tank actually full? You can see that from the small access in the sole plate. If it is full then you just need to recalibrate the instrument. If it is the original instrument then press menu and the calibration is listed there.
Aug 11, 2010
28
Thank you very much. I wasn't aware of calibration. I'll check this weekend.
thanks again. I'll update as soon as I know.
Aug 11, 2010
28
Thank you for the help
I pulled the gauge on the tank and just slid the float up and down. It moved fine. I filled the tank, and it did fill 100%.
put the gauge back in and it works perfectly.
strange.It must have been stuck.
thanks again
