Jim
The above engine is installed in an O'Day 28, which is on land in a cradle.I recently started the engine without any problem and ran it with an appropriate water supply. It ran very well and I stopped and restarted three or four times, but when I attempted to start it a few hours later, it would not crank. Some time later I discovered that the bottom cylinder was full of clean water. I have searched the net for information, but have only been able to find one meaningfull reference which suggests that the problem is a gasket failure between the water pump and the main power unit.I will be gratefull if someone could advise me as to the following points.-Could the leak be due to another gasket - cylinder head maybe?-Is there a website or forum where I might obtain detailed information on how to proceed with the repair?-Can the powerhead be removed without disturbing the seating of the lower unit to the hull.Hoping for news.Jim.
