OMC Saildrive
Feb 6, 2015
6
ODay 28 Lake Lanier
Any idea on how long the gasket or main seal (where sail drive passes through the hull) should last.
I just purchased a 1981 ODay 28. Previous owner (owned for 2 years--bought from an estate) did not know if/when gasket was replaced, have no records before his purchase. Boat has been in fresh water for at least 10+ years, maybe longer.
I'm hauling the boat soon for new bottom job. Any thoughts or recommendations on replacing this gasket?
Thanks
If you Google saildrive, or do any research...
From a recent discussion, right here on this forum, 7 years, from what I've read.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
No further info from me but I did have this reference for the operator's manual.
The engine is a regular OMC 25 HP from that same period.. The bellows for the hull-to-engine joint is probably not available but a good rubber supply place could supply some stock to make one from.
http://sbo.sailboatowners.com/components/com_mtree/attachment.php?link_id=8130&cf_id=24
Good Luck and welcome aboard
that rubber you want is Buna the same thing they make o rings out of it comes in many thicknesses stuff is tough as nails any o ring manufacturing company will have it in stock
Nov 6, 2006
10,152
Quick note; I think the water pump impeller in that saildrive is in the leg as it would be in an outboard motor.. In that saildrive, I think it requires being out of the water to change it.. If the boat is dry, might be something to get done before launch.
Feb 6, 2015
6
ODay 28 Lake Lanier
Oct 9, 2012
10
Oday 27 Fairhaven, MA
Thanks
Yes, if it's not leaking, don't touch it. I do have an intact one if you're talking about the flat gasket. I you're talking about the one that goes between the top of the leg and the first adapter plate, that is an actual o-ring. Haven't been able to find one in three years, so mine stayed where it is. No leaks, don't remove it is my advice. BTW - I have a 1974 O"Day 27. Good luck with the boat!
Oct 17, 2011
2,809
Ericson 29 Southport..
Parts for this setup are getting extremely hard to find. The last one I worked on was difficult to even find a water pump impeller to go in it. Hoard parts if you can find them..
