Older two wire Mast Light
7
Catalina 25 Jamestown, PA
Gang:
I've recently aquired a 1981 Catalina 25. Found a two wire arrangement from the mast light / to a connector on the deck. The connector has 3 pins --- any idea of which wire goes to what pin?
Thanks!
Oct 2, 2006
1,517
Jboat J24 commack
Well
Any light needs two wires
On a mast the bulbs are small (10 watt) most of the time and IF there were two bulbs there would be one 12+ for each bulb and they would share the - wire
What's there now is anybody's guess and you would need to use and electric meter to see IF power is reaching the plug and which pins do each function
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
I had a single steaming light on my mast, with 2 wires, but a 3 lead plug. I guess they had 3 pin plugs at the factory. Use a 3 pin for a boat with masthead light and steaming light, and just ignore 1 pin for a single light boat.
It doesn't really matter which pin goes where on a 2 conductor light using 3 pin plug, as long as the two pins with wires line up. On a polarized LED light (some festoons from Dr. LED are polarized) it will matter...
I replaced my old 3 pin plug with corroded contacts with a 2 pin trailer style plug.
Brian
May 27, 2004
2,059
:dance:And if you decide to add the second light (i.e. Steaming, Anchor, Deck) make sure the switch that activates each matches the light that comes on!
Nov 19, 2011
1,489
MacGregor 26S Hampton, VA
I have seen where the third wire from the plug is a ground to to the mast and the other two wires are the positive to each light and their negative just grounds.
I personally have two harnesses coming out of the mast and one plug on the deck and I plug the appropriate harness into the deck plug. I don't see much opportunity to use both the anchor and steaming light at the same time. I also only need one switch.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
We redid our mast with a trailer-plug too. (caveat - we're only in freshwater) They're cheap and available everywhere. I occasionally give the pins a wipe with grease.
