Older solar intake vent.
Feb 22, 2011
80
Hunter Legend 37 Muskegon, MI
I don't even know who made or makes it (circa 1987). It is a single speed, single direction intake fan with a dead C size nicad battery. Couple of questions. 1-Can I replace the battery with a lithium equivalent? It works perfectly on solar. I'd like day/night ventilation. 2-Can I reverse polarity and make it an exhaust fan? No bells or whistles needed, it keeps working when the sun shines.
colemj
Jul 13, 2004
813
I suspect you cannot replace the NiCad with a lithium because most rechargeable lithiums require a charger with some smarts built into it. A direct connection to a solar panel like these fans use will not be sufficient. Why not just stick with a NiCad replacement? They last for years.
Interesting question on reversing the polarity. These fans came with both exhaust and intake blades, with the exhaust blade being the default one installed. Are you sure yours isn't already setup for exhaust? I don't know if the motor will run in reverse with reverse polarity. I have spare motors for these that I could test for that, but I'm away from the boat for a few weeks.
Mark
Conceptually yes. Unless an engineering student decided to install a diode to prevent the reverse polarity. You know batteries do not do well when you play with the polarity of the cells.
You might try to swap the wires on the fan motor. The motor is not sensitive to polarity it accepts the flow either way then just turns.
At least that is my understanding. I’d try it and be attentive to any sparking/smoke/ or burning smells
Likes: Timm R Oday25
Feb 22, 2011
80
Didn't know about the "smart" chargers for lithium or swapping, so I asked and got an answer. Nicad it is. Thanks jssailem and colemj. Everything looks sealed and the wires disappear in the case so I think I'll just replace the nicad and live with. Might try some jumpers from the battery to the fan for a test. If it had a replacement blade it's long gone via PO. Have some green to remove and then it'll be as good as can be expected for an old fan.
degas
Aug 14, 2023
47
Tanzer 29 Lake Ontario
This.
I have a Nico solar-charged vent for the head, vintage of at least 6 years old, likely over 10 years old, surely powered by a NiCad battery, endures a proper Canadian winter every year.
It's usually obscured by my dodger but when it gets sun the fan usually runs all night.
