older Raymarine L760 Instrument
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
Came across this in deep storage. Don't have the power cord but would like to power up. Can someone tell me which pin is + and -? I believe the power pins are top right and lower left (3 o'clock and 9 o'clock from the internal tab)1684800033549.png
Can you see the wires on the inside of the plug? They more likely can give you a clue.
You have the female end... Are there wires behind the pins?
Wires connected to pins often give a clue as to purpose. Red & Black are your desired ones.
RitSim
Jan 29, 2018
457
I could figure it out if I had the plug. I've looked on the Raymarine site and it appears the device is too old so the info is not there.
Joe
Jun 1, 2004
8,223
Looks like you need to open the case to I.D. the wires. bummer.
  • Helpful
