I'm trying to remove the centrists on my '71 O23. This is an iron keel with a pivot pin that goes all the way through the c/b and not a lead keel with c/b wedges.
Sometime in the past, the pivot pin was replaced with a bolt and lock nut. I was able to remove the nut and bolt but it appears that there is some kind of a sheave that the c/b hangs on and it is out of round where it passes through the pivot hole.
Any ideas on how to get this out?
