What I Did, Brian
...on my Dad's 29 PS with exactly the same problem was to purchase an electric fuel pump at an auto parts store. I put long, big leads on it with clamps for the battery terminals and an in-line switch. I picked up a three-way valve and spliced it into the fuel line outside the transom. I then pumped the fuel out into containers. A couple of issues: you will need some big containers. I suggest swap meets, asking around the docks, etc. You may have to do it in several steps. For disposal, call the county and ask where the hazardous disposal facility is and tell them you have old gasoline. They will probably have a couple of times a month you can bring it in, but the containers will be surrendered to them. Thus the need for cheap ones. In my case, my Dad's gardener took it all. It ran fine in the old gardening motors, even tho it wouldn't run in the big OB. Good luck, Brian, it's definitely a PITA and explains why some people just dump it someplace in the middle of the night, which I am NOT suggesting. What I am saying is that there are more barriers than solutions. Also, no fuel station, boat yard or other facility would accept the gas. Rick D.
