Old Fuel
A lot depends on how old the fuel is and if it was conditioned. You may want to start by draining a few ounces of fuel into a glass jar from the primary filter. If the fuel has water in it, algae, or just plain crap, it will be evident. That said, if you can gain access to the tank by removing an inspection plate, sender guage, or similar opening, you would be best advised to drain the fuel out (and clean the tank, too, if you can) and dispose of it at a toxic waste site. The cheapest device to drain the tank might be a brass Par hand pump. Whateve pump you use, make sure it's rated for use with fuel.FWIW, I've found that "old" fuel that was properly conditioned at the outset can last a "long" time. Still, draining the tank is clearly the best option, if possible.
