david cole
Best method for removing old bottom paint. One company want to use a wet sand blast mixture, to remove the old bottom paint. While others use scotch brite pads to cleanup, followed by Interlux 202 and two coats of paint. By the way both will hydroblast the bottom with high pressure water as the boat is removed from the water.This wet sand blasting system is new to me, will it hurt the gelcoat??
