Beware
Before you start, ask if you can afford to go cheap, since it may involve doing it over again later. I used the birch veneer ply from HD for a bathroom vanity re-do in my house -- essentially the same stuff, but a bathroom is dry, compared to a boat. For a boat, 3/4 inch is likely overkill. Are you planning to stand on this thing? What are you attaching it to? You don't want the cabinet to be stronger than what's holding it to the boat! The veneer is also amazingly thin. Don't sand it much, or you'll wear through. Marine ply would be better, since it has fewer voids in the inside plies where moisture can get trapped and cause problems, and also comes with veneer options. With marine or standard materials, be sure to epoxycoat the edges of every piece to prevent moisture from wicking into the plies. Moisture will at the very least lift the finish, before starting to delaminate the entire sheet.
