L
LaDonna Bubak - CatalinaOwners
Hi Peggie,I tried the hot towel trick on all the hoses. No smell. I added KO a couple of weeks ago & there was a small amount (maybe a gallon) of "stuff" in there. Still smells bad. So I did some poking around. Here's a little history: the system was new about 4 years ago. The hoses are that high end white USCG approved hosing - not permeated according to your hot towel test. The odor is definitely coming from the input/output area, not the vent (opposite end of tank - no odor). The connectors were installed with plumbers tape and there are no leaks BUT they're not screwed in all the way. The output connector is the loosest as I can move it easily by hand. The others are pretty tight - I also tightened all hose clamps but there wasn't much tightening needed. Could odor be escaping through this/these connections but not leak? Should I clean the system out & tighten everything up or would that matter?LaDonna
