opinions
My opinion of heavey oil mixtures is mostly negative. Extra oil fouls plugs and pollutes lakes. These same engines, when rigged with oil injectors run a 100 to 1 mixture at virtually all power settings under 3/4 throttle. That is why, with modern oils, most manufacturers recommend a conservative 50 to 1. Yamaha was recommending 100 to 1 for their 15 HP outboard, which is the most aggressive I have seen with a standard 2 cycle.Jeff Peltier
