Oil stain removal
57
Hunter 31 Port San Luis, CA
Does anyone have an answer to remove used motor oil stains from the gelcoat. I was changing my oil yesterday and the hose from the suction pump I use to do the change came loose and squirted oil all over the cockpit. I wiped it up as soon as I could but it still left stains. I used "LA's Totally Awesome" spray cleaner on it and that helped a little but you can still see the stain.
May 24, 2004
7,176
CC 30 South Florida
Keeping the gelcoat waxed usually prevents the stains. I would use some mild abbrasive compound to try and remove the stain. For stubborn stains I use 800 grade wet sandpaper and then wax.
Dubo
Oct 26, 2010
86
Hunter 340 Deltaville Va
I'm not sure if FSR can handle oil in gelcoat but it works great on other stains. I agree with above about waxing. Typically lacquer thinner will cut oil so maybe you can start with that and I don't think it hurt gelcoat.(try it under a seat first)
