Last night we were on a 190 nm passage from Manzanillo, Mexico to Ixtapa. Just as I was about to come on the 3 AM shift, the oil low pressure alarm went off. I raced up and looked at the panel and I could see that the pressure gauge was reading correctly. When I changed the engine RPMs, the pressure did what I expected it to do. We had a little wind, so we put up the sails and sailed at 2-3 kts. I checked the engine oil levels and they were fine.
Amazingly we had very limited Internet access and I texted Dave Balfour, who's a great friend and was responsible for commissioning BlueJacket when he worked at Freedom, and described the issue. He said to believe the pressure gauge and not the idiot light. What wind we had finally died and I fired the motor back up. The light was on, then went off as expected, and then a minute or so later flickered on. We ran with it on for hours and then it suddenly went out.
I replaced the oil pressure switch in 2011 by accident. I had wanted to replace the sender unit but the part # in the manual was wrong. Unfortunately I didn't keep the old switch.
This is on a Yanmar 3JH2-TE. Note that the oil pressure sender and the pressure switch take their readings from basically the exact same location.
Anyhow, the area where we're at is basically devoid of marine services and we have 600 miles to go along some pretty desolate coast. I might be able to find a diesel mechanic in Acapulco, but I'm not sure. Scary thought!
Does anyone have any experience with something similar?
-- Geoff
