oil pressure sensor quandry
Mar 21, 2021
4
Hunter 50 CC San Francisco
My 50CC has a Yanmar 4JH4-HTE with Teleflex i5501 engine monitoring. After erratic oil pressure readings (0 to 80 psi at steady 2300 rpm) I replaced the sensor with an Yanmar OEM part. Now I read zero pressure all the time! I can see no part number on the old sensor and a second new Yanmar sensor didn't improve things. I found some Teleflex info that indicates 0 psi should result from the highest resistance (240 ohms) and full gauge reading at lowest resistance (33 ohms). The Yanmar part reads 33 ohms at zero oil pressure which would seem to say it won't properly function with the Teleflex system.
Has anyone had to deal with this issue or know what the correct part number is?
Does anyone have any documentation for the Teleflex i5501 monitoring gear?
Feb 10, 2004
4,176
Hunter 40.5 Warwick, RI
Easy to troubleshoot. At the sensor disconnect the wires, power up and look at the gauge. It should read zero. Now short the two sensor wires together and look at the gauge again. It should now read full scale. If the gauge performs as described, you have a USA standard gauge.
Now with the engine off measure the resistance of the oil pressure sender without any wires connected to it. It should read about 240 ohms. If it does,then the sender and the gauge are compatible and are both the USA system. If the gauge reads zero all the time you have an open connection in the wiring to the sender.
With the engine running the oil pressure sender should read some value more than 33 ohms and less than 240 ohms.
If the oil pressure sender reads 33 ohms without the engine running, then you have an European style sender and it is not compatible with your gauge.
See the attached files for more info.
4
Rich - thanks for the really helpful input. I've researched further and found that the Yanmar "standard" part is spec'd at 10 to 85 ohms. The new Yanmar sensor reads 10 ohms disconnected however my old sensor is reading 85 ohms disconnected. I found Yanmar has a second sensor rated at 85 to 10 ohms and this would align with your comment that a US version would read high resistance at zero psi.
Now all I have to do is find the part here in Puerto Rico!!
Thanks again...Pat
Likes: Daze
Jun 15, 2012
717
BAVARIA C57 Greenport, NY
I think the threads on the sensor are all 1/8" NPT. Any auto parts shop should have either American or European ohm output in stock. Bring the old sensor with you and you could match the threads.
  • Helpful
1,150
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
The sender port on the motor side are BSPT (T=tapered) 28 threads per inch. - not NPT 27 threads. Get an adaptor like this -- Amazon.com: GlowShift 1/8 BSPT Male to 1/8-27 NPT Female Gauge Sensor Sender Thread Adapter Reducer : Automotive. Obviously verify the ports size - motor block and sender - before you order the adapter.
Anyway - the motor side port is probably tapped into aluminum. So tighten just enough (and no more) for a no leak seal. The central point is don't try NPT direct without an adapter. Otherwise you can crack the aluminum casting when you try to fix the leak that is being caused by these mismatched treads. Likely repairable but very inconvenient and pretty costly to fix.
Charles
Boiler
Feb 15, 2022
36
Hunter 49 Houston Texas
Fo a Yanmar 4JH4 engine with Teleflex ECU (translator?).
Has anyone figured out how to use a standard 240/33 ohm pressure sensor? I am assuming the issue is in the Teleflex and how it is wired, can a couple of resistors be installed or is it more complex? Unfortunately, electricity and electronics are voodoo to me.
Oct 26, 2010
2,171
Hunter 40.5 Beaufort, SC
Why not buy a standard USA pressure sensor with 1/8 NPT male, a 1/8 NPT to 1/8 BSPT adapter, and a matching (ohm range that is) USA pressure gauge to fit in your engine panel. I did just that and it works like a champ. The wires won't care what type of sensor or gauge you use. Finding the USA standard parts are straight forward. The only caution has already been expressed DO NOT TRY TO THREAD THE 1/8 NPT fitting into the 1/8 BSPT female on the Yanmar.
They make the gauges with various diameters and various ranges. I am sure you can find one of the appropriate diameter. I know I did. Pick a range that puts your expected normal operating pressure at about mid range. That should be a gauge that reads from 0 to 100 psig or so.
Just a suggestion. You should be able to buy everything you need for less than $150, maybe way less.
Boiler
Feb 15, 2022
36
I purchased the crossover and a standard VDO 240/33 ohm 10bar pressure sensor and it did not work. Is there a different ohm range available?
