oil pressure light on after start button fix
19
Catalina 30mkIII austin
Hope some one has an idea. my start button went bad and i replaced it ,then i started the
motor and the oil pressure light stays on ,also when in lift the kill handle the buzzer
warning the key is on does not buzz.light stays onwith engine running. is there a connection between the light buzzer and the start button?? or does my iol pressure have a problem and buzzer went bad all at once after
changing start button..
Thanks for any ideas it is a catalina 30 1996 ..
is there an easy way to ck oil pump...
Steve
