oil indicator light
Jwhy
Feb 11, 2013
101
Catalina 320 Kilmarnock
Should the oil pressure light come on when the ignition key is turned to on?
Jan 4, 2006
7,318
The question you want to ask yourself is ..... " Is the engine running when the ignition key is turned to ON ?"
If it's not running, there's no oil pressure, so for sure you want to see that low oil pressure light doing its job.
