oil in exhaust water
Apr 2, 2016
1
Catalina 30 Kill Devil Hills NC
Noticed a little oil in the discharge water after starting engine for 1st time this season. What are the possible reasons ?
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
could be from sitting all winter with fuel oil in excess in the cylinders...could be blow by oil from the crankcase breather tube ,or maybe to much oil in the crankcase ...
Mar 20, 2012
3,983
its probably normal...
an engine needs fuel to start, and a cold started NON-computer engine cannot possibly burn all the fuel cleanly that may be in the cylinders upon initial cold startup, and a very very small amount of fuel residue can leave a noticable oil rainbow on the water in certain conditions... as much as it may always happen, we hardly ever notice it, and gas engines are worse than diesels for this.
the other thing is, there could have been some exhaust soot that has broken loose and was discharged....which often happens with an engine that hasnt been run in quite awhile...
