How much oil
How much oil are we talking about???There are several different areas that could cause oil in the bildge. first wipe the engine down around the valve cover and the oil filter, run the engine until it gets warmed up and looke for oil in those to areas, if you have oil around the filter I would suggest changing the filter as the oil filter seal could be damaged and might not reseat properly, if it's around the valve cover then I would try to tighten it up. Let Me know how much and where the oil is located and I can help you out more..I'm in the owners directory.Mike Markus
