Oil Filter Replacement
May 2, 2012
276
Catalina 310 Toronto, Ontario
Hi all AGAIN. Just going over my notes to start the usual yearly boat check and wondered if anyone has found a replacement for the Oil Filter on the Universal M25XPB engine? Some feed back was FRAM but with hesitation about quality. Any chance that you may have come up with a solution for this.
Cheers
2 Old Pirates:)
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
I just use the OEM. I change filters on average twice a year. The OEM filters cost $16.80 so you aren't going to save much by going aftermarket.
pk104
Jun 30, 2009
207
Catalina 310 Atwood Lake
I use Kubota oil filters P/N 16271-32090. I think I pay about $5 for them. The Amish use the same motor we do on their generators that I am sure run more then my motor does.
Bob S
Sep 27, 2007
1,774
Beneteau 393 New Bedford, MA
Jesse,
I use a Baldwin B227 oil and BF940 fuel filters. I pick them up at Associated Diesel on Freeport St Dorchester- not far from you.
Nov 18, 2010
2,441
Jesse,
No it is not. I purchased my water pump from them when I changed it out a couple of years ago. Thanks for the tip.
