I bought one of those pumps at harbor freight that you hook a drill up to and it's supposed to transfer fluids. I got all set up, poured a little oil in the pump to lube it and commenced to easily changing my oil with no mess. Well, there was no mess because no oil ever came out of the engine. I never got the pump to ever work. I tried filling the tube with oil, sucking on it(yuck) and running the pump the other way. I bent a coat hanger and put it in the tube to ensure it would reach the bottom of the crank case.
Has any one used one of these things to transfer oil successfully?
I thought all the oil in the engine got pumped through out the gear case as well. The oil in the gear case looked brand new. IF it is supposed to be pumped through out I have a real problem!
Do you take your oil to a diesel mechanic or an injector shop to have it tested?
