Oil alarm and overheating
Feb 18, 2015
4
Ranger 28 clipper cove san francisco
hi, we have chartered a jeanneau 34 a newer model and we're stuck just 1 day into our sail up the delta! After motoring for hours at 2-3k rpms the oil overheat alarm and red indicator came on. We stopped the engine and sailed our way into the nearest harbor. Other than the obvious checking oil and fluid levels anything else we should attempt to get going? It's a newer Diesel engine, I'll look up the specs and repost. Is this a common problem? Thank you!
I'm guessing from brochures it might be a Yanmar 3YM20 engine? I don't think that would have an actual oil overheat alarm; more likely it has an oil pressure alarm and a water overheat alarm. If the problem is overheating than the usual thing to check would be whether the engine is pumping water out the exhaust. If not than check that the seacock is open and that the sea water strainer is clear. If the alarm is for oil pressure than check the dipstick to make sure it has oil. I don't know what else could cause low oil pressure.
David's advice is good.
Have you contacted the charter company?
May 12, 2004
1,505
I have the 3YM20 engine in Fraulein II. The oil idiot light is a low oil pressure alarm. The other is the overheat alarm. Check the fluids but DO contact the charter company. I'm in the charter business and charter companies do not like charterers tinkering around. That is why they usually don't put tools on the boats...people will use them.:yikes: Keep the boat in a safe place and let them figure it out. Reduce your liability.
Likes: NYSail
NYSail
Jan 6, 2006
3,145
Beneteau 423 Mt. Sinai, NY
Roland is right.... make the call, open a beer and leave it to them
Gunni
Mar 16, 2010
5,937
#1 reason to charter a sailboat not own one! "The engine quit, we'll be at the dock bar, call when it is ready!":D
Likes: jon hansen
