OI33 prop size
3
- - pensacola fl.
what size props and what is the pitch on an OI33 with a 50hp perkins. i believe the reduction is 1,5 on the gear
Ross
Jun 15, 2004
14,693
The calculator on boatdiesel.com
Says Three blades 13.5 diax7.5 pitch increasing transmission ratio will improve prop efficiency. I used 29 feet lwl and 14000 pounds displacement.
F
Frank Saul
OI33 prop
13.5 Dia sound a bit small If you have a borg waner you may have a 2.56:1 gear I have a 18X15 on mine now But I am changing morors to a Vetus m4.17 And I need to reprop not only because of the lower HP but the rotation is the opposite. Would you mind giving this a try in the calculator Gear reduction 2.63:1 Displacement 16000 LWL 27.5 42HP Thaks for your help Frank
