Oh no, must the keel go!
C
Cherilyn Rutledge
I have a 1984 C22 with a swing keel. It seems the keel cable is wrapped badly around itself and actually is partially off the winch. There is so much tension, I cannot move the keel up or down at all. Since I an a novice sailer, how much trouble am I in? The boat was launched yesterday.
G
greg
been there
You have several options: 1. If the boat is on a trailer, use a jack to lift the keel(and SAFELY BLOCK IT!) so you can untangle the cable on the winch. This would work if you have enough room above the keel to lift it slightly into the keel slot. 2. If the boat is in the water, head for shallow water. When the keel touches bottom it should lift enough (depending on water depth)to give the keel cable slack on the winch. 3. Another method when the boat is in the water is to walk a line back from the bow. Each end of the line is brought back to the port and starboard winches. Secure one end to the port winch and crank the other end with the starboard winch (note: use a chafe guard on the rub rail! also note this procedure is reversed for lefties or those cruising below the equator ;>) With great effort, this method will work, although it helps if you dive in the water to help position the line on the keel to get the best mechanical advantage. That keel is 500+ pounds! I have tried all three at one time or another. The 3rd option is very hard to accomplish but it definitely works. Hope this helps.
C
Cherilyn Rutledge
Thank you
Thank you for the great advice. It is also comforting to know I am not the only one that has had this problem.
Rod
how?
I also have an '84 C22, how does this happen? What should I do to prevent it?
C
Cherilyn Rutledge
I wish I knew
I am not sure how this happened. One possibility is that the cable became loose around the winch while we were trailering the boat. Once the boat was launched, the swing keel dropped just enough to put tension on the cable. If we knew right away that this happened, I guess we could have put the boat back on the trailer to relieve the tension. Unfortunately, we were well on our way to our mooring. In the future we will definitely make sure the cable is wrapped securely around the winch before the boat is launched. Any other suggestions?
John
Similar thing happened to me
My boat is older ('74) and had the old small drum dia. winch. The same thing happened when I launched for the first time. Luckly it was only for a day sail. I have since upgraded the winch with the refit from catalina direct. But now I still stick my head down so I can see the wire rolling on the winch to make sure it winds evenly.
C
Cherilyn Rutledge
It worked!
We were easily able to untangle our keel cable by manually pulling the boat up the launch ramp. The keel was lifted enough to take the tension off the cable. It was so simple. Thanks again for the great advice.
