Off the wind headsail sheeting
For an inexpensive, low tech, but effective, means of adjusting the headsail lead, especially where there are limited track options, you might consider this.1. Rig a block (forward track block) at the track position that is "close hauled" for the headsail. 2. Rig a block (after track block) at the after end of the track or, instead, use a spinnaker turning block if one is available.3. Rig a block (running block) to the end of a line the size of the sheet (running block lead). It must be long enough to reach a convenient cleat with sufficient excess to allow for easing.4. Run this line through the forward track block. 5. Run the sheet first through the running block and then through the after track block (or the spinnaker turning block)and then to the sheet winch.6. When unfurled, the headsail will be sheeted through the aft track block.7. When the running block lead is fully eased, the headsail is "downwind". (And still can be poled out.) When the running block lead is fully trimmed so that the forward track block and the running block are touching, the headsail is "close hauled". Most times, you'll want it somewhere in between. Trim or ease the running block lead to produce the best sheeting angle for the boat's heading. 8. Trim or ease the sheet as required.9. Of course, you need the same setup on both sides.10. It seems that this was easier to do than to describe. I'd be glad to take e-mail questions directly at sailingbauble@aol.com.I have used this system for a while and it works for me. At times when the strain on the running block lead is too much for me to trim without a winch, I just luff the headsail briefly to lighten the load while I make a needed adjustment.Since I singlehand leisurely and don't race, I don't mind if tacking is a little sloppy.
