Odors From Ventline When We Flush
As promised Scott B here is a quick resume of my phone conversation with the HeadMistress about our problem
IMMEDIATE ACTION SUGGESTED TO STOP ODORS FROM VENT LINE WHEN WE FLUSH:
1- use Odorlos in waste tank every 5 days for now to start and maintain the process of oxygenation and pump out everyweek, full or not
2- new, shorter vent line, even if it means climb angle of more than 45 degres ( mine is longer and sweeps around in a wide arc to avoid steep climb I assume) to be replaced asap by larger, ideally 1 1/2" diam. with new larger thru-hull and and tank fitting as far from edge of tank as possible, in the center would be best spot I think, where it would be the least to spill out in vent line when heeling on either side)
BEST PRODUCT TO REMOVE PERSISTING ODORS IN BOAT
assuming the bilge is clean and there is no residue from previous spill during main sewage hose replacement (miss Peggie mentions that the black hose with green stripe that was used is the best that can be had) during this conversation I mentionned the older original sewage hose from tank still in place to the macerator and thru-hull for pump out at sea that could have hardened waste in it an be responsible for some of the lingering smell inside boat, (even though all cushions and matresses were cleaned professionnally this spring, by selling broker) she suggested that we remove and discard this older line completely as we are on Lake Champlain where we cannot use it anyway and plug the tank with a 1.5" plug with plenty of teflon tape available from most hardware store.
The product which she recommends is PURE AYRE available from Petco, Rite Aid, to use in all compartments and recesses and anywhere else that we might suspect as a source for odors, it is a food base product unharmfull to pets, humans and kids. she says expensive but definitely worth it it is not a mask like Feebreeze, it destroys and remove the odors accordind to the manufacturer.
FINALLY A SHORT STORY TO ILLUSTRATE HOW BAD VENT LINE ODORS CAN BE
Miss Peggie says, picture 2 man standing with water up to their chest enjoying a glass of wiine near shore directly behind a shoal draft boat
when one of the ladies who just used the toilet walks into the cockpit after flushing and pumping and looking in the direction of their 2 mates, only sees 2 glasses of wine being held at arm's lenght over the surface of the water while their owner not being able to stand the smell had chosen as a solution to immerse their heads under water while holding their glasses of wine above water and no doubt their free hands pinching their noses. it would make a good commercial.
tks Peggie for this little wink, which reflects very well, what we are talking about in this post.
