KO spray PEGGY YOU ONCE INDICATED THAT YOU CAN USE KO RIGHT OUT OF THE BOTTLE TO GET RID OF ODORS IN THE CUSHIONS. WHAT IS THE PROCEEDURE AND IS IT NECESSARY TO AIR THE CUSHIONS OUT?THANKSFRANK
Remove the covers. Spray enough K.O. on both sides of the foam to penetrate to the middle...not soaking wet, just the whole cushion. Spray the covers separately. Put everything out the sun to dry for a day. While you're at it, spray all your musty PFDs and foulies down with K.O. and put them outside in the sun for a day too.
It's not a spray...you'd put it in a spray bottle to use on cushions, carpet etc. It's live bacteria in liquid suspension that "eat" spores and bacteria that create odor...similar to--but MUCH more potent and less expensive--the microbial products sold in pet supply stores to eliminate odor from pet accident sites. It'll get rid of any organically caused odor. Available at all major boat stores and the online chandlery here: http://shop.hunterowners.com/detail.tpl
