O'Day Swift
My neighbor wanted to give me an O'Day Swift, because he was moving and didn't want to take it with him. I was going to take it, but I hesitated because it needed a new mast,sail, and the gudgeon's were missing. Not only that, but it needed more work and money put into it than I wanted to spend. I have another sailboat that I enjoy using, and I probably wouldn't use the Swift much if I did take it and fix it up. Having said that though, I probably could have purchased the parts from Rudy Nickerson of D&R Marine in near by Assonet Ma. and fixed it up. If your Swift is in pretty good shape and you need any parts for it, I suggest that you talk to Rudy. I'm pretty sure that he could make you up a dagger board for it, if he doesn't have one in stock. Also, as far as the paint goes, I imagine that it has the original gel coat on it, but there are epoxy paints like Awl Grip, that are easy to install and could make that boat look like new. The paint is very expensive, but you wouldn't need much for a boat of this size. The question of whether it's worth it, is a hard one for me to answer. Having never sailed a swift, I don't really know. The only way you can find that out, is to talk to someone who owns one. Most sailboats like the Swift and the Sunfish don't really offer too much head room when you try to tack them, and if you don't mind that, it's okay. Anyway, it's a choice that you'll have to make for yourself. Here is Rudy's web site. Good luck!
