G
George Demmy
Is there some form of traveller on the Sprite that makes use of the two formed openings on each outside corner of the transom. I just found this Sprite lying in a yard for 20 years according to the Owner. The transom plywood was pulp but the hull is clearly salvageable. I've removed the coaming and the inside face of the transom and have just reglassed it with polyester foam core. Rigging and sails were kept inside and are fine. It looks like it will be a fun little sailer. Any Sprite owners out there?
