O'Day Spars
A
AWKIII
I have an 1982 O'Day 37 Center Cockpit and need to replace the masthead or end up purchasing an entire new rig.
Does anyone recall who manufactured the spars for O'Day during this time period?
Thanks!
RobG
Jun 2, 2004
337
Ericson 28 Noank, Ct
One of the manufacturers was
Dwyer Aluminum Mast Co. (DAMCO). Still in business and the web site can show you if your a match. http://www.dwyermast.com/
I have a Dwyer mast and have delt with them. They were great.
BarryL
May 21, 2004
1,126
rigrite
You can try Rig Rite at
http://www.rigrite.com/index.htm
I believe that o'day used Isomat spars.
I have ordered from Rigrite in the past. They can be difficult to work with but they have the parts.
Good luck,
Barry
Thanks!
Dec 8, 2006
1,085
Oday 26 Starr, SC
Re: rigrite
O'Day mast were apparently made by many manufacturers. Even the same model boats often have different spars and booms and turnbuckels and you name it.
Use the previous post as a starter. Use a template of the size and shape to help match end of mast to masthead. Consider that if you get close having a local machine shop use your template to get it to fit.
Also you can use clay and plaster to make model of shape to insure fit.
Ed K
26
