O'day plastic corners used on 332 ,some 35, and some 39
564
Oday 39 Lake mills WI
On the brochure attached you will see the corner of the galley in the foreground. On my boat, these corner pieces appear to be plastic. They were covered with years of teak oil ,cooking oil, dirt, grime and maybe some varnish. I have no idea what they should look like or how they may have been finished. Gloss /matte?
Does anyone have these pieces in their original state ? Or any suggestions as to a good finish for them? replacement??
Any suggestions would be very helpful.
Pat
Jun 7, 2004
1,250
There are plastic (grey) on the 272 as well....on the corners of the various salon fiddle raisl, etc....It had to have been to save money....most of ours did not fit exceptionally well, though we still have them....Pat
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
I'm pretty sure they are metal on the 35 if I am interpreting your note correctly. Mine show some signs of corrosion. No idea where you could get a part like this? Probably have to custom make something.
Jan 27, 2008
3,086
Great input 25yearslater. I am positive these are aluminum on my boat but I think they coated them with varnish or whatever they used on the woodwork so there is some kind of finish that starts to flake off over time (after 25 years I guess you should expect some deterioration). The corner piece is exposed to water from the sink a lot so thus the corrosion problem with aluminum.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
Thank you jibes. I knew I had seen something that might work. I also ran across the source of aluminum 1/4 round. Bosch Rexroth has aluminum shapes often used for machine guarding. Navigating their site is the biggest challenge but architectural aluminum components has the profiles that are very similar to what the brochure shows on Oday. Don't give up, it's a tough site to navigate.
Nov 3, 2010
564
So how should I finish them? I see some in other boats that appear to be painted black for the long corner piece and silver for the fiddle. It looks OK, anyone with a bitter idea? I thought about painting them a color closer to the wood but I think that will look like I'm trying to hide them.
What do we think of these? http://www.buckwoodcraft.com/teak_molding.htm#Teak Molding
