Mast Raising System
Yves,I keep my boat on the trailer and rig each time I go out. I found this link (see below) and built the system described at the bottom of the page. I made a few improvements...I use 2 double pullies between the A-frame and the deck fitting on the bow. The 4:1 purchase makes raising the mast very easy. I also attach the A-frame to the life line stancheons (sp?) via a pair of swivels. This prevents the A-Frame from binding. I place each leg of the A-frame on a small piece of 2X8, just forward of the mast base. It takes me about 5 minutes to set this rig up as I use snap rings on all points. The rig cost about $50 to build.Here is the link:http://mywebpage.netscape.com/TedsSailingPage/Mast_Raising.htmlLee
