O'Day mast wiring
41
Oday 34' sloop Deltaville VA
I need to run a coax cable inside the mast of my 34' O'Day to just above the spreaders. Does this mast have a sleeve for electrical lines? If so is there one or two? Where is it located? I have a cross section of the mast in my manual, but there is no indication of a sleeve for wiring. I inserted a coat hanger wire into a couple of openings in the mast and could not feel anything that seemed like sleeve. Any information I can get on this subject would be appreciated.
Mitch
Oct 22, 2008
21
Oday 34 Lk St Clair
On my 1982 34foot Oday, there is a plastic sleeve running up the mast for the electrical wires. If I remember it is attached to the front side of the mast. It starts about a foot from the bottom and stops about 6" from the top. Hope this helps.
Aug 8, 2010
41
Thanks, Next month I am having the yard install my anntena just above the spreader. Any info I can get will help.
