oday identity
nos
Aug 6, 2009
5
oday unknown na
could someone help me identify my boat that i have recently purchased
the owner said that it is an oday 30 .. however a good friend has said it is an oday 28 .. there is no hull id on the transom and from a rough measure of loa it seemed to be 29' and the shaoe of the stern would suggest an oday 30 compared to the photos of other oday 28's and 30's
Dec 8, 2006
1,085
Oday 26 Starr, SC
Captain Nose
Nose,
This web site provides a plethora of information. Captain Herring and his minions provide much detailed model information. Suggest you compare model information for the O'Day 30:
http://oday.sailboatowners.com/inde...ymodel&id=123&Itemid=888&brand=Oday&bmodel=30
Compare to:
http://oday.sailboatowners.com/inde...ymodel&id=124&Itemid=888&brand=Oday&bmodel=28
AND, look at the photo galleries provided...
Does your title reference a hull I.D. or model description?
Ed K
O26
nos
Aug 6, 2009
5
oday unknown na
i have already checked out both of those sites ... and done the side by side compare ... unfortunatly i dont have a title for this boat .. i really should get in touch with the previous owner to see if he has it ... where i live is populated by transients and things like papers go missing all the time ... could you answer if the hull shape of the transom on the 28's was always the same and likewise for the 30's .. if the hull shape which i am sure didn't change as they would have to remould .. then i would assume it was a 30
Jun 11, 2004
1,927
Oday 31 Redondo Beach
Can you get out a tape measure and compare your numbers to the specs on the prior post?
Jun 1, 2004
95
Hunter 27 Cave Run Lake, Morehead,KY
Please Post Pictures of Your Boat
If you do, I'm sure that someone will be able to tell you what you have.
Dec 8, 2006
1,085
Oday 26 Starr, SC
Captain Nos(e):
Are you in the USA? If yes, you will need paperwork. Is the boat Coast Guard Registered?
The hull I.D. # should be imbedded in the hull on the tansom. Hang your head over the starboard corner of the transom and look carefully. It is probably same color as adjacent area. Take small piece of white paper and use lead pencil to highlight number on paper. That is put paper against hull number and gently rub lead against hull number. That is rub lead flatwise to show number outlines. Rub sufficiently to get complete number.
Ed K
O26
The problem with riverboat gambling is that you can't tell if you're queasy from losing your money or getting seasick!
nos
Aug 6, 2009
5
oday unknown na
Captain Nos(e):
Ed K
O26
not in the USA
i looked on the transom and couldn't see any identifying marks
Jun 2, 2004
1,952
Oday Day Sailer Wareham, MA
No Hull I.D. Number? No Title?
My advice is to take this boat back to ever you bought it from!!
ALL O'DAY boats built after the 1972 Model Year have Hull I.D. Numbers. The 30 was introduced for the 1977 model year and the 28 for the 1979 model year. The HIN will be molded into the outside of the transom and read like: XDYSxxxxM77A for the 30 or XDYNxxxxM79A for the 28.
ALL boats 14' and over require a Title in the USA, you will not be able to register or document the boat without a proper title and HIN.
This may very well be a stolen boat!
As to whether she is a 28 or a 30, here are a couple of pictures of the 2 boats. If you saw them hauled out, the 30 has a deeper forward entry (bow sits lower in water)
But first the official specs of each design.
O'DAY 30
O'Day 30 Specifications
L.O.A.
29'-11" (9.12M)
L. W. L.
25'-5" (7.74M)
Beam
10'-9" (3.28M)
Draft (keel)
4'-11" (1.50M)
Draft (centerboard up)
3'-6" (2.18M)
Draft (centerboard down)
7'-2"
Sail area
441.3 sq. ft. (41.0 sq. M)
Displacement (keel)
10,500 lbs. (4775K)
Displacement (centerboard)
11,000 lbs. (5000K)
Ballast (keel)
4200 lbs. (1909K)
Ballast (centerboard)
4700 lbs. (2136K)
Mast above water
44'-0" (13.42M)
O’DAY 28 Specs
LOA: 28’3”
LWL: 22’11”
Beam: 10’3”
Draft: 4’8” (deep-keel) 3’8” (shoal-keel)
Displacement: 7300# deep-keel 7700# shoal-keel
Ballast: 2550# deep-keel 2950# shoal-keel
Sail Area: 396.9 sqft
Masthead above DWL: 40’1
367
Oday 20 Seneca Lake
in nys, depending on how old the boat is it may not have a title, but would at least use the registration from the previous owner to transfer. if you lack the registration, you must at least have a bill of sale which includes the vin number along with a pencil rub of the number. if unreadable, you may need to get the sheriff to verify the number.
even if not in the usa, i would suggest you quickly find out the requirements and get the paper work straight before the seller disappears. :eek:
nos
Aug 6, 2009
5
oday unknown na
thankyou for the advice ... the guy who sold me the boat is reputable and i know it isn't stolen as the history of the boat is known on the island .. nyway .. i do have a bill of sale .. but no hin ... luckily today i found the hin ... it was painted over on the transom with the name of the boat ... and now i have managed to identify the boat and manufacturers year .. unfortunately i cannot find very much information about the boat .. just for your info .. its a ranger 28'
Sep 20, 2006
367
Oday 20 Seneca Lake
looks like a great boat and ranger's are supposed to be a good boat and pretty quick. i don't think oday ever used a metal slotted rubrail so that would have been a good clue.
