Hey guys and gals,Just bought an 1985 25th adniversary DaySailer. On the bottom of the tramson, on the starboard side, there is a open drain, proably below waterline. Common sense tells me to plug it in the water.... Any ideas?The cockpit is self bailing, and has a plug in the cockpit that releases on the bottom just behind the skeg. That's not the one in ?, but the other.The 2 access panels in the cockpit (4" round threaded) revealed the open part under the cockpit to be full of water (where the flotation foam is). It drained out the hole I think I need to plug.Thanks in advance for any ideas!-Brad
