Winged keel
Bert - I don't know the math & am too lazy to look it up, but bolting a plate across the bottom of your keel will effectively give you a "winged" keel, which will increase the effectiveness of the keel and reduce leeway etc etcDave Gerr's "The Nature of Boats" has discusses the theory,and I'm sure there's lots more data to be found elsewhere. The distance the "wings" have to extend out from the keel to be effective vs the increase in drag is something you'll have to find out by trial & error, or by crunching a lot of numbers. If you do create a winged keel, you'll have to be very careful not to bump into the bottom, as I imagine a bent "wing" would negate any advantage you gain. Just speculation, but I imagine that the "wings" would exacerbate any tendancy of your boat to pitch in a seaway,and increase drag in so doing.Lots of stuff for you to figure out during the off-season. Good luck.
