Gents,I was sailing the other day in my newly purchased '79 O'Day 37 with a Perkins 4-108. I went into the aft cabin and heard a mechanical sound. I discovered that the drive shaft was spinning. I tried putting in all gears but the shaft kept turning. It works fine under motor, and I tried to put it in reverse without way and then started sailing. The shaft started spinning. Are the clutches gone? How do I repair that? Should I put vice grips on the shaft to stop it from spinning during sailing to save wear on the trannie? Can it wait until the fall?Thank you,Dick
