Have any O'day 35 owners removed the shaft from your boat? I went to replace the cutlass bearing and shaft log hose last weekend and found that the shaft will not sneak by the rudder. I was hoping that with the prop and coupling off and stuffing box removed, I'd gain enough clearance. Didn't happen. What did you do? Drop the rudder? That was more work than I was ready for. Remove the strut? The nuts are directly under the full gas tank. Pull the engine? Yeah, Right.
