O'Day 35 keel material
2
Oday 31 New London, CT
All,
I am trying to determine the keel material (lead or steel) of the O'Day 35.
Any info would be great.
Thanks,
Lou Leverone
O'day-31 / Zephyr
May 26, 2004
168
- - Oriental, NC
Lou
My O'Day 35 keel is lead with stainless steel "J" shaped keel bolts. 5200 between keel and stub with zigzag pattern coverage in the joint with a band of 5200 around the outer edge of the joint. More info than you wanted but I thought I would give it to you all at one time.
Goodwinds
DaveM
May 30, 2006
365
Oday 34 Chesapeake Bay
I concur, my 34's keel is made of lead. 34's and 35's are basically the same boat, except for the 35's swim platform.
DaveM, I take it that you've had your keel off. My x-ray vision doesn't see through lead so well.
2
Thanks for the info....
Thanks for the information. I was hoping the keel was made of lead.
I've been sailing my 31 for 5 years now. It's a great boat but we're looking for something a bit larger. Can't find anything that we like better than our 31 except possibly the 35.
I've owned other O'Day's and also Catalina's (plus a few specialty boats) over the past 30 years, but I prefer O'Day's over anything else in that class of boat.
Lou
Goodwinds
DaveM
May 30, 2006
365
Excellent job on the keel Barry. I've encased mine in epoxy but am having a bit of trouble keeping the bottom paint on.
Oct 7, 2008
380
Oday Oday 35 Chesapeake Bay
My keel is also lead. Barry, did you see any blisters after you soda blasted on your hull?
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Epoxy coat for lead and bottom paint
I couldn't keep bottom paint on my lead keel so I stripped it down to bare lead using a belt sand and sanding disk on an electric drill. Ok to rough up the lead a little as the whole point is to remove the lead oxide that form from exposure to oxygen. Metal oxides are very difficult to get paint to stick to (think aluminum oxide, used for grinding wheels for example). So once down to bare lead, as soon as possible coat the keel in west system epoxy. Let it cure then coat it again. Before it is completely cured paint the first coat with epoxy barrier coat that will bond to the epoxy chemically. Add another coat if desired for full coverage. The barrier coat acts as a good primer for the bottom paint. Now before the second coat of barrier coat is fully cured paint with a coat of bottom paint, this should chemically bond with the barrier coat to form a lasting high adhesion layer that will resist peeling. Let it dry and add as many more coats as desired depending on the type of paint (ablative, etc). I did this to my 35 maybe 9 years ago and never had adhesion problems on the keel again.
