O'Day 35 carpet replace?
9
Jenneau 27 Rented
Has any replaced the carpet liner on the cabin walls? If so, is it difficult and what do you recommend to replace it with?
Thanks all
DK
Sep 16, 2009
68
ODAY 25 Lake Travis
Its a bit of a pain scraping out the old liner but it is possible. if its the original, its actually a piece of fabric with a thin layer of foam behind it, it is glued directly to the fiberglass hull. Scraping is really the only way to remove it. i had the best luck with metal trowel you'd spread sheet rock joint compound with. then used a metal brush for all the cling-ons. elbow grease. people have chosen everything from high end mold resistant Marine carpeting to Home Depots / Lowe's outdoor floor covering... your budget will determine that. I'm in the possess- the slow process -of installing stingers with fiber glass and attaching a paneling for the wooden-boat look in the saloon and a mildew resistant carpet in the v berth and aft quarters. it'll be a pain - I've got a 25' and you've got 10+ feet than I but it's certainly a good opportunity to do some customization to your vessel! TIP: if you can remove the existing fabric in one piece it can serve as a template for your new coverings.
