Oday 322 shroud tension
Jim McCaslin
I need the tension specifications for shrouds on Oday 322. Does anyone have the factory specs? Thanks.
J.B. Dyer
Morning Jim
The "specific" information that you want may not be available. I don't know anything about the 322, however, I do have an O34. The original users manual on mine indicates that the tension on the cap shroud is hand tight plus five extra turns, each side. The lower shrouds are all hand tight. There are no numbers indicated. This may be the case for the 322, I just don't know. I hate to keep beating Rudy Nickerson up, but he may be the guy that can give you the proper answer. He can be reached at DR Marine, 508 644 3001. Sorry I can't give you more specific information. Good Luck!
Jim McCaslin
ODay322 shrouds
Thanks for your input. My owners manual provides some proceedure informaiton, but nothing specific on tension. I'll try your 034 recommendations for a starter, then compare leeward slack on opposite tacks in moderate breeze to fine tune.
