O'Day 30 engine coolant overflow
Oct 4, 2009
8
Oday 30 Magothy River, MD
Had my 1980 O'Day 30 surveyed today. Surveyor noted that engine did not have a coolant overflow tank and indicated that one should be installed immediately, if not sooner. This didn't come up when I had boat surveyed when I purchased it. Looking all around engine compartment, I cannot find a place where the overflow tank would have even been installed. Engine is a Universal.
KISS. Get a small Rubbermaid container with a screw on top, use wire ties to hang it on the wide of the engine compartment. Done.
What engine? Universal made many different models. It'as like saying I have a Chevy block...
Engines 101 - The BIGGEST & BEST collection of M25 Series Universal Engine Information on the Internet, plus some M35, too :)
http://www.c34.org/wiki/index.php?title=Diesel_Engine
RoyS
Jun 3, 2012
1,742
You may not need an overflow tank. My heat exchanger has a fill neck that is four inches or so tall. That space is large enough for the expansion of the small amount of coolant in the system. I never add coolant and it never overflows. An overflow tank would be useless.
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
Overflow tanks are a convenience. Keeps coolant out of the bilge, and you don't want to be pumping coolant overboard so you'd have to mop it up.
However, it may be that your overflow hose is routed to a recess, and not the bilge.
I have 2 overflow hoses, one from the manifold and one from the water heater expansion tank. The hoses are routed to either side if the motor, to recesses between the engine mount stringers. If I put too much coolant in, she spits it back out when I run the motor. It's auto-leveling.
Now I just know how much should be in there when cold.
Jul 5, 2011
754
Oday 28 Madison, CT
Ditto on the O'Day 28, at least mine.
Pat
Jun 7, 2004
1,250
The overflow in our O'Day 272 is in the lazarette...very handy spot.
Oday 30 Stamford CT
TinKicker...... I own a 1983 O'Day 30' with a Universal 16 hp (model 5416) engine. The boat did not come with an engine coolant overflow tank. I purchased one from Hansen Marine who is a Universal/Westerbeke dealer. I installed it on the aft side of the bulkhead between the engine compartment and the galley and it can be viewed via the port side engine compartment hatch. Its a easy way to check the level of the coolant without taking off the radiator cap and eliminates any air pockets in the cooling system.
Jul 22, 2011
146
Mariner Yacht Co.(NH) Mariner 28 Atlantic Highlands, NJ
Google coolant overflow tank. I got mine through Amazon, something like $6.00. You may not need it, as mentioned, but then how many boat parts can you say you bought for under $10.00? There are fancy aluminum one for around $75. Absolutely no need to get a Marine Spec tank, any old tank will do. Lots and lots of options.
Lou
